rear agitator effect on speedometer
Old 11-03-2011 | 06:44 AM
traveler's Avatar
traveler
I just added an 18" rear wheel/tire, and when I stood it side by side with the 16, it looks to be about 2 inches taller.
I guess I'll have to use a GPS to measure speed and then know where the speedo is at.
~Joe
Old 11-03-2011 | 06:52 AM
skratch's Avatar
skratch
if it looks 2 inches taller when side by side, then you didn't use a low profile tire which would put the overall diameter in roughly the same place.
Old 11-03-2011 | 08:38 AM
'05Train's Avatar
'05Train
16" rear wheel & tire measures 25.33", 18" measures 26.18", or right around a 7/8" difference. Yes, this will throw your speedometer off, yes, it's an easy fix with a TTS.
Old 11-03-2011 | 11:47 AM
traveler's Avatar
traveler
Tire is a D407~180/55B18 on my H/D Anarchy wheel
Stocker is a 180/65B16
Maybe some if it is that the stockers is at least half worn out, and thus has a bit of a flat spot in the center.
~Joe
Old 11-03-2011 | 11:50 AM
traveler's Avatar
traveler
Well, I use a PC-V with an Autotuner.
I'll just have to check the speed with a GPS, figure out the variance, and mentally make allowances for it when I ride.
~Joe
Old 11-03-2011 | 02:39 PM
skratch's Avatar
skratch
using the tire calculator that i refernced in an above post, the 18 inch tire should have a diameter of 25.8 inches, while the 16 inch tire should have a 25.2 inch diameter.
so new tire to new tire, your 18 inch should be slightly more than 1/2 inch taller
Old 11-03-2011 | 02:47 PM
RoadMonkey's Avatar
RoadMonkey
I was looking into that wheel upgrade. I wondered about the same thing. I had to install a speedohealer on my Hayabusa just to get an accurate speed reading with everything stock. I will plan on the low profile rear tire combo.
Old 11-03-2011 | 02:51 PM
Cowboy Rob's Avatar
Cowboy Rob
Big Kahuna HDF Member
I went with a 18 inch rear,and according to the police radar on the side of the road it's off 2mph.
Old 11-03-2011 | 10:04 PM
skratch's Avatar
skratch
which way? is the speedo reading faster or slower than you are actually moving? if faster, i would ignore it and act as if it is accurate. we can all use a little 'cushion' from time to time.....
Old 11-03-2011 | 10:15 PM
traveler's Avatar
traveler
exactly.
Quick Reply: rear agitator effect on speedometer
