Fix for 'Clunk' - progressive monotube fork inserts.
To the OP, how many spacers/c-clips did you use on your drop? You went with a 1" drop correct?
I did the 2'" drop. Installed only 1 c-clip on each side and it bottoms out. Luckily it doesn't hit the fender. I contacted Progressive and got 2 different answers from 2 different techs. One said add a 2nd c-clip, the other said don't use any c-clips. I'm not sure what else I need to do. Any suggestions would be greatly appreciated.
ADRENALINE RUSH
04-24-2015 05:33 PM
