Another Road King Idle questions - Is this dangerous?
Old 10-16-2011 | 02:59 PM
nvsteve's Avatar
nvsteve
Possibly just a dirty IAC orifice. Happens to mine once in a while.
Old 10-16-2011 | 03:15 PM
aktid35's Avatar
aktid35
Are you holding the front brake when your stopped? That alone will make mine rattle your fillings, keeps the suspension from soaking up most of the vibration
Old 10-16-2011 | 08:51 PM
mglax13's Avatar
mglax13
I just also came over to a Street Glide from a Honda Spirit 1100 (basically the same bike as you) and you definitely notice ALOT more vibrations when stopped and ALOT more other noises that you never heard with you Honda, however it does seem like something's awry based on the comment you made about your clutch. Good call on the indy mechanic, I seem to trust them more than the HD stealerships.
Old 10-16-2011 | 09:01 PM
cromagnon's Avatar
cromagnon
Originally Posted by Rockrivr1
Thanks everyone for the advice. I appreciate it. I'm going to bring it to an independent Harley mechanic and have it checked out just to see. If they say it's normal, well, then it's normal. I also want them to check out the Cam Tensioners anyway just to be sure there's nothing wrong there.
lol, I have to agree. My friends said my Honda sounded like a lawn mower. After a while, I had to agree with them.
At 22K, on an 06 checking cam tensioners will likely be a waste of money. You should get over 50K on those things.
Old 10-16-2011 | 09:56 PM
Bill03E's Avatar
Bill03E
they didn't change the tensioners until the 96" motors, and having his checked is a very good idea ,coming from a guy that has 2 motors go from wasted tensioners, one at 23,000 , and one at 68,000 miles on the bike but less than 19k on the 3rd set of tensioners. I would check them.
Old 10-16-2011 | 11:24 PM
dirtracin23's Avatar
dirtracin23
Originally Posted by HammerheadC4
Check all the motor mounts.
+1
OP - You shouldn't be pulling in the clutch to start braking. Except for down shifting, you don't touch it until you're almost stopped.
Old 10-16-2011 | 11:41 PM
genedjr's Avatar
genedjr
OK, on the "jiffy stand" does the bike actually move on flat level surface? By that I mean without anything else, just the bike idling, doest the "jiffy stand" (sorry HD terms ) move off the spot you sat the bike on?
If it does - your idle has been set to low - you have a bad injector that is inconsistant - you have a clogged airfilter causing a very rich condition - you have a loose motor mount (any of them), or the motor mount has failed (any of them), or very very rarely you have primary issues (generally a failed part in the clutch). Or anyh combination of the above. (are we having fun yet?)
If not - normal.
Harleys do shake, alot compaired to any non-45 degree bike.
...genedjr
Rattlehead73
09-20-2020 10:25 AM
Shawn Albro
02-12-2017 08:53 PM
teeniesgrandpa
Engine Mechanical Topics
01-27-2017 10:45 PM
smithbrl
01-22-2011 12:52 PM
cravenc
08-22-2007 02:46 PM
Quick Reply: Another Road King Idle questions - Is this dangerous?
