dynojet power vision
https://www.hdforums.com/forum/touri...g-is-here.html
+1 to a T.
I use it, also from FuelMoto with Jamie's map, Jackpot Mufflers, FM Air Cleaner and a woods TW-555 cam. How does it perform, well, here is a dyno sheet from a bike Jamie did two days before mine with the exact same setup, comparing stock to modified. All I can say is it runs GOOD, REAL GOOD!
Im using it and like it better than any of my previous tyners (PCV, Fuel Pak, PC III, and SERT) Very easy to use and understand. It can also be used for a code reader.
If your going to buy one call Fuel Moto, not only do they have a much larger and more complete library of MAPS than Dynojet but by getting it from them you get lifetime tech support and they double the warranty of the unit
Andy Gallaher
03-06-2016 07:51 PM
RBJones
03-24-2006 07:47 PM
