10" Monkey Bars with stock wires, lines, cables?
The only thing I changed when I did mine was the handle bar bushings. I went with the poly ones instead of the stock ones.
You will have to reroute the clutch cable from behind the radio to below it an you'll have to reroute the wiring harnesses inside the fairing to make up the length needed. You can always swap the cable and add extensions later relatively easy if you want.
....and the brake line was fine?
Dave
