Wideband O2 sensors
They are actually called broadband sensors because they read a broader range. Unless the their calibration is checked, you should not trust their accuracy. With proper installation, within their operating range the narrow bands are more accurate. Either sensor only outputs a voltage. The switching function is driven by the ecm.
Wideband sensors are not manufactered or designed to be used as an input sensing device. They can not react fast enough to provide accurate feedback to the ECM. They are meant to be used as a "post" reading indicator to insure that the ECM has calculated the best air/fuel mixture. If the wideband sensors were so much more accurate, dont you think the OEM designers would put them in to start with? When the ECM is calculating the mixture required, it needs the narrow band sensors since they work in a narrow band, they are able to respond fast enough to provide the ECM with intelligent and accurate information. Go investigate Bosch website and read their disclaimers about the use of wideband O2 sensors.
