factory PSI
Mine was at zero from the factory.
A week later, it was zero again. Been fine ever since, I'm guessing something wasn't seal properly at first.
I usually run it around 30-35 psi
I find that statement hard to believe and without seeing the design specs or other manufacturers literature to prove otherwise, I don't believe it.
If this were the case you'd constantly be adding air to the shocks. And if you are constanly adding air, then you have a leak somewhere in the system.
I went on a 9,000 mile ride this summer and set the shock pressure at 20psi before I left. A month later when I returned home, I checked the shock pressure, and it was exactly 20psi.
Maybe I didn't hit any bumps???
20 is a LITTLE light for the new frame. Should be around 30 or so.
Could you substantiate that statement? Wear did you get that information?
Amazing, eh? I guess I never hit bumps either! I've not lost a single pound of air pressure in my last two bikes, that's four riding seasons now. Some dealer probably told him that and he believed it.
THAT
IS
SOFA
KING
WEE
TODD
DID !
Bingo - look in manual for Rear Suspension Recommended Air Pressure Table (my 09 Touring manual is page #64). Set air according to weight & dial-in when you ride. Need to get hand air pump from HD to check & adjust.
