Question: Trailering a Touring Bike in the Rain
I would leave the bike uncovered and wash it when you get it where you need to. Anything you try and cover it with to protect it from and of the road elements will more than likely do more damage. Trailering in the rain will do no greater harm tham riding in the rain which will only result in road grim is all. Hopefully your open trailer has some sort of stone shield on it to protect any gravel from being kicked up from the towing vehicles tires. This is the only area that I would be concerned about
Best advise. DON'T COVER IT WITH A TARP or anything else! Unless
you want scratches all over your tins, etc.
Rain water won't hurt your scoot. Just make sure you have enough straps hooked up. I have used the handlebar and BSR foot pegs. you can also use the saddle bag supports too.
Good Luck and have fun in Florida!
YB
YB
I secure my Ultra to a trailer utilizing the triple tree, passenger floor boards and lower front forks at the point the brake calipers are attached. Works great. If you use the search function on this forum you will find great advice and in many cases pictures of securing a bike to a trailer.
Never cover a bike on an open trailer.
1 Post
Thanks for the replies. I'm using a 5x9 ramp trailer from U-Haul with the built in wheel chock for the front wheel. I really like these trailers. They're sturdy and protect the bike well except for something falling out of the sky. They have lots of tie-down rings and good, sturdy side rails.
I've got it tied and strapped down quite well. I'll check the straps and tie-downs periodically. I brought it up here to Tennessee several months ago using the same type trailer and tie-downs and it arrived without a scratch.
Thanks again for the advice.
1. Make sure you check the tires. I had a bad tire experience with that trailer. Wasn't the trailers fault. No damage but it did provide an opportunity to spend 4 hours on the Chesapeake Bay Bridge in 115 degree heat. That story just keeps getting better as time goes on.
2. Use "soft loop tie downs" with "soft ties" to secure the tie downs to the bike. They work great and don't scuff/scratch the bike.
Just my
Not sure how far in advance you have to reserve it but the daily charge is only $14.94 IF you pick it up and return it to the same location. U-Haul discourages one way trips with this trailer.
ManicKernel
04-07-2012 07:31 AM
