Swap out the air in your tires
Old 10-09-2011 | 09:59 AM
SeeMeDo's Avatar
SeeMeDo
while you're at it make sure you wipe down with winter lemon pledge.
Old 10-09-2011 | 10:05 AM
oldbie's Avatar
oldbie
Too many pollens and molds in this October air. I had to put some antihistimine in my tires with the new air. I used liquid Dayquill , it helps balance.
Old 10-09-2011 | 10:08 AM
onaride63's Avatar
onaride63
I like using helium. helps with the gas milage. My bike seems like it floats down the road.
Old 10-09-2011 | 10:09 AM
ericl's Avatar
ericl
I have been running 78% nitrogen with no problems so far, however there is another 1% of inert gases, I think they use the other inert gases as a solvent that keeps the nitrogen from falling out of solution, i asked my local stealer if he could increase the nitrogen ratios he said he would call his supplier to confirm. I'm pretty confident my current ratios are correct as I live on the gulf coast (sea level) so I don't have to adjust for partial pressures like some of the guys in higher altitudes.
If I add helium, particularly to my back tire will it effect the settings on my progressive 940 shocks? I just got em dialed in.
Old 10-09-2011 | 10:27 AM
drukanfu's Avatar
drukanfu
Old 10-09-2011 | 10:36 AM
Just Dave's Avatar
Just Dave
Just a reminder for you folks that have bikes that are still under warranty, you MUST USE ONLY Certified MOCO air. Make sure you pick up Winter Blend.
Old 10-09-2011 | 11:09 AM
fabrik8r's Avatar
fabrik8r
Kudos Dave, you win!
Old 10-09-2011 | 11:11 AM
Jackie Paper's Avatar
Jackie Paper
Originally Posted by SleeplessinVegas
Quit typing and go riding.
I am ridding, remember TEXT is you friend.
Old 10-09-2011 | 11:16 AM
Karnevil's Avatar
Karnevil
just had my 30k service done. my dealer only uses Nitrogen. in fact they told me that if i need to add air to my tires for any reason the next time i come by there, they will deflate the tires and put back in pure nitrogen again free of charge. i think thats a bit extreme, but it doesnt bother me since im not paying for it each time.
Old 10-09-2011 | 11:18 AM
scooty2321's Avatar
scooty2321
To not void your warranty ...you MUST use Genuine Harley Davidson air in your tires.Part number ou812
Quick Reply: Swap out the air in your tires
