New wheels installed... Bike almost 2 inchs higher... How do I lower?
So I bought a new set of wheels, 21 front, 16 rear with a metzeler tire the same size as my stock tire.. However both the front and rear sit almost 2 inches higher than stock wheels..
What parts will I need to lower a 2011 Road King back down an inch or two in both the front and rear.
What is the width of the rear rim? If it's nearly stock width, if the RK comes with a 16" rear rim, and since you're using the stock size tire in the rear...it's illogical that you'd have increased the diameter of the wheel/tire combination by 4"...which would provide a 2" increase in rear height. I'd recheck the measurements in the rear, and measure height in line from the rear axle center straight down to the ground. The front's another matter...
The reason I mention rim width is it's conceivable that running a much narrower rim would 'squeeze' the sidewalls and cause the tire diameter to increase. But even then...not by 4".
My guess would be you haven't raised the rear. Everything that's changed is as a result of what was done up front. (To lower the front, you can put in reduced height springs. If Progressive has sorted things out, I believe they have a cartridge front-end that can be adjusted to lower 1" or 2". There were a number of complaints about the Progressive system, so I'd make sure they've addressed the problems before I purchased one).
Alan
Alan
Compromise might be a better word than destroy. I assume you put the big wheel up front for appearance; you now have two different diameter wheels so your two axles are no longer running at the same height. Changing the axle height on one wheel is similar to changing either the front or rear suspension height, it has an effect on handling characteristics. Now you're wanting to bring the saddle height back down either for looks or to accomodate your inseam. When you lower the front suspension to compensate for the higher axle on the big wheel, you will loose suspension travel and reduce the abiltiy of the front end to absorb bumps, and you will definately alter chassis geomety, but I'm not familiar with how it will effect your ride. Best of luck finding an honest opinion about the suspension and handling of one of these trendy big wheel set ups. If it looks exotic and "cool", it probably handles less than desireable.
to each his own
Bwana
