SE heads
I checked the part # in the current P&A and Zanotti's and didn't find it , however if you are referring to the SE perf Heads, they have 72 CC chambers and flow about 218CFM vs 186 cfm stock . While have heads ported for your cam is ususally preferred , good results can be had with them . I'm running SE perf heads with 95" cast flatops and an Andrews TW31G and get 98hp and 101 lbs ft . They will handle up to .575 lift .
They can be cleaned up to flow much better .
Was just curious as to the specifics of these particular heads. Someone has these for sale along with 95 cylinders and pistons for $500. Seemed like a good deal but can't find much info on them. Also looked up the part numbers and found nothing. They were previously used on a Deuce. Thanks for the info guy's but not a big deal. I'll put the money towards 26g's instead.
zenmedic
Exhaust System Topics
44
12-31-2008 08:45 AM
