Longer k&n oil filtor kn-173c ?
I AM CURENTLY USING the K&N 171C OIL FILTOR .
i know a guy who uses longer K&N 173c filtor on his 96 twin cam .
is this ok ?
because kn site says its for older evos
http://www.knfilters.com/search/prod...x?Prod=KN-173CPart KN-173C Product Specifications Product Style: Oil Filters
Height: 5.984 in (152 mm)
Outside Diameter: 2.98 in (76 mm)
Thread Inside Diameter: 3/4" UNF
PSI Relief Valve: Yes
Anti Drain Back Valve: Yes
Style: Canister
Removal Nut: Yes
Gasket Material: Nitrile Rubber
Filter Material: High Flow Premium Media
Bypass Valve: Yes
Finish: Chrome
Weight: 0.91 lb (0.41 kg)
Product Box Length: 3.25 in (83 mm)
Product Box Width: 3.25 in (83 mm)
Product Box Height: 6 in (152 mm)
is this ok ?
Style: Canister
Removal Nut: Yes
Bypass Valve: Yes
Finish: Chrome
I dont think so m8. The bypass valve release pressure is I suspect lower which may cause oil to bypass the filter more often, and you would be surprised how often this is likely to happen anyway. I also think it is a larger filter medium so wont do such a good job as the one designed for the twincam. I could of course be wrong but I would suggest if you mail K&N they will give you your answer.
WB
WB
Rooster6
Oil Archive (no new posts)
02-13-2009 12:06 AM
