Help with top fork nuts....
Got a service manual? You need to turn the forks all the way to the left and then turn the ign switch to the fork lock position with key in the switch. With a flat blade screwdriver locate the release button underneath the switch and press up and turn the switch another 60* ccw. Lift and remove switch. Watch out for a spring when lifting the switch. You may then have to insert a flat blade screw driver into the ignition in order to unlock the forks. Remove the nut from the post to remove the cover. There are 2 T27 Torx screws on either side of the inner fairing to remove the fairing cap. There is also a plug that you have to disconnect to fully remove the cap.
trigger1911
01-17-2010 01:44 PM
