which starter
which starter
I have a 2008 flhtc with 18000 miles and starter went out. Starter just spins when engaged. Someone told me the starter clutch probably went out. The motor is a 103 inch and about 10.1 to 1 compression with manual compression releases i only use when it is really hot out. I thought starter should last longer. Should i put another stock starter in or is there a better after mkt. one. Not sure what to do. Thanks.
easy to fix.
and I'd suggest that over replacing your starter.
a rating such as "1.4" refers to how much electrical power the starter pulls from the battery---NOT how much rotational power it produces to turn the primary.
lots of poor quality "lotso chrome" starters and other gee gaws out there.
you might save yourself trouble by using the compression releases more.
mike
mike
easy to fix.
mike
mike
If you do decide to replace the starter, the 1.4 kw is the only way to go, in fact the 1.4 kw was stock on my 2010 Street Glide (which is now stage II 103). It spins right over with the releases.
Yep! +1 starter clutch. The HD one sucks! I replaced 2 OEM ones before I found thies guys. 57,000 miles on this one so far and a lifetime warrenty also.
http://www.mesmotorcycle.com/street.htm
The stock compensator is garbage and contributes to starter clutch failure. When my starter went out, I also upgraded to the screaming eagle compensator and everything works much better. No more compensator windup prior to turning the engine over and no springback on the starter clutch (which kills the clutch) from the crappy stock compensator.
