i have a 2008 FLTR Road Glide, i just picked up a used Ultra Classic seat marked 2008 and up touring models. the seat was mfg oct 2010. when i mount the seat the back of the seat is about 1" above the fender mounting screw hole, any suggestions other then using a spacer and a longer screw.
Agree, the tang may not be in the correct position in the slot. Never seen it but could the seat pan be bent? It may just need to be pushed down some toward the hole in the fender because of the angle of the tang . shouldn't use a longer screw or a spacer.
Will try reinstalling the seat again this weekend. 10/7/11 got it to fit properly tonight. what a PIA, the tour pac mount was holding up the back of the seat after pushing in the foam on sides it went down into place
