What causes gear whine?
...+1...also...as an example..if you think about how reverse sounds in a car as you backup more than just 1-2 miles an hour..if you give it some gas, you here a really loud type of "whine"...that's cause the reverse gear in a car is "straight-cut"...it's done for extra strength, but the side effect is the whine, which is actually, metal-to-metal contact...hope that helps..
08's and 09's all do it in 5th gear. I got use to it on the FLHX Street Glide I had. I did start using a gear saver oil which is much thicker and it reduced the whine a lot. I also run it in my 2010 Ultra but it never had any gear noise as they have correct the problem by making all the gears the same.
so the story is strength, hard shifts and whine vs quiet, easy shifts and less strong.
if you look at the 09, 10, 11 model year technical forums ( google for the .pdfs), you'll see that the gear cut was changed back and forth on 5th and 6th
I don't think the 12's are any different than the 11's
mike
mike
I had a Yamaha that had all straight cut gears, and at certain MPH's the wine was just deafening from the transmission. The only fix is to change speed or gears.
I agree with Dave, my 2010 Ultra has gear whine in first, perfectly quiet in fifth and all the rest. I have heard of this problem from a Shriner I met on the road. He sked if I had a problem with it. He told me the moco was aware of it & there was a TSB for it, said many of his friends had the same issue. Have you taken the bike to the dealer & complained?
