Power Commander V and Factory/Extended H-D Warranty
Old 10-05-2011 | 12:34 PM
inaroush's Avatar
inaroush
BULLSH!T... Wont void a damn thing unless that dealer wants to be an assbag and not warranty the problem. I just bought a 5 year extension and my delaer said in NO uncertain terms not to worry about a thing. I am covered!
Old 10-05-2011 | 01:15 PM
jackja25's Avatar
jackja25
Keep in mind it is not written that way from the MOCO. That is up to the local dealership. I am up in the DFW area my dealership installed the PCV for me, has been about two years. And I have taken it in for warranty work locally and out of state. And no mention of voided warranty. MO
Old 10-05-2011 | 01:53 PM
pauly3's Avatar
pauly3
This is all great info and I am going to press my dealer to see if they will change their tune. If not I am going to call the other H-D dealer in town who is actually listed on the DynoJet website and see what they say.
Old 10-05-2011 | 01:54 PM
Tooth's Avatar
Tooth
I was told that anything that enhanced the performance of the engine and does not say HD or was installed by an authorized dealer sets the owner up for void of warranty. The exception is something obviously unrelated....ie radio issue.
Everyone can get off their feet about this and relate what their dealer has told them but the issue becomes if my dealer in Oregon tells me one thing and your dealer in Kansas says another and I break down in Kansas...guess whos paying?
Old 10-05-2011 | 05:08 PM
BlackBetty's Avatar
BlackBetty
I would have to agree with Tooth.
But, I will relate what my stealer told me. He said anything that burnt into the ECU would void the warranty, but something like V&H Fuelpak would not and that's what he recommended. Now I been doing a lot of research and asking a lot of questions and one of the shops here said BS and that they recommended the PCV and would warranty it there if needed(not a HD stealer, but an HD authorized service joint).
But I think I'm close enough to FuelMoto to just have them do the whole deal and be done with it!
Down with the man!!!
Old 10-05-2011 | 05:20 PM
frog13's Avatar
frog13
Exactly what I did, and after 38 years of riding these iron beasts, I have never been happier with the way my machine runs.
Old 10-05-2011 | 07:06 PM
Bill03E's Avatar
Bill03E
Do not "press" your dealer, put it on yourself, then if you have to take it to the dealer for any reason take it off, they will never know.
Old 10-05-2011 | 07:27 PM
lh4x4's Avatar
lh4x4
Life lesson number 33609. Never every ask the staff at a dealer what you should do. Their reply will always be that you should use the stuff that they sell and make money on. It would be like asking Madof if you should invest your money with him.
To make matters worse some will LIE and say your warranty will be voided. Gasp fear and vomiting! Wrong!
Just do your own research like you are doing now and decide what you want.
There are many programmers out there so look at them all. Everyone has a favorite. For me the plug and play Cobra Fi2000R and the new PRO are the best going. Easy to install and totally plug and play no expensive dyno needed. And the bikes run stronger and cooler. What else could one want. Oh! And better mpg's.
By the way add on programmers don't "burn into the ECM" they add instruction downstream of the ECM. Another line of BS from the dealer staff. The idiots may even believe their own misinformation. Only the SE various stages do that.
I don't let the dealer do anything except recalls or warranty work if ever needed. Even then I ask a lot of questions and check out what is going on. I have been able to access HD engineers at the rallies for info on recalls.
RCUltra
Milwaukee Eight (M8)
17
03-25-2018 10:09 PM
TriGeezer
04-19-2017 12:10 PM
cap_njack
10-22-2014 08:29 AM
Toby_2014
10-05-2014 08:23 AM
MurphyPeoples
06-21-2013 12:25 PM
