head pipe with cat ?
I have a 2009 SG ca model with a cat
Im looking to replace my head pipe with a non cat head pipe Stock one just to get rid of some of the heat I have Rineharts slipons on it my question is will it need to re flash the ecm by using a non cat head pipe already has a stage one and flash
also anyone have a part # for the stock head pipes with no cat ?
Thanks Tim
Thanks Tim
Check with some of your local Indy's. The good ones have already built jigs for forming and welding up a pipe section for the part of the cat they cut out of the stock pipes. A heck of a lot cheaper than getting new headers from Charley, if you can even get them.
If you can't find a good Indy, give Danny a call at Danny's Cycle in Montgomery, TX. He has some catless pipes (stock with cat cut out) on the floor. Saw them last week. He will take your stock pipes on a trade then cut the cat out for the next customer.
http://www.dannyscycleshop.com/
Your second best option (IMO) would be to go with an after market header such as Rinehart, Jackpot, Vance and Hines, Super Trap, etc. Yes you will need a high flow air cleaner and a good tune. Sounds like you are going through the normal progression. Might as well get yourself some good cams and replace the bearings. The bike will now accelerate when it makes all that noise. That will make you happy.... For a while.
It's pretty easy to cut it out yourself...if you're not up for that, another option is American Custom . com They have catless head pipes.
If you have a good tune right now and the only thing you are changing is removing the cat, you will NOT need to do another tune, the ECM will adjust for that relatively small change in flow.
Kevin
Drawing - FREE Custom Foot Pegs
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
OR
Another option for 2009 catless head pipe is I frequently see HD pipes on Ebay for $50 to $100 if you want to keep your stock head pipe. They are popular for late model touring bikes going with no O2 sensors or adding O2 sensors in the lower location.
valleybuck (03-24-2017)
My recommendation would be the Jackpot 2-1-2 headpipe from FuelMoto. It has both 02 sensor location/sizes in the pipe, fits perfectly in place of the stock pipe, and uses the stock heat shields for a perfectly stock appearance.
Then you hang on to your stock pipe with the cat in case you ever need it in the future.
