Technical question on O2 sensors
agree....but the optimal is 13.5:1 AFR and the passive approach used in the XIED/VIED's will get you to about 14.2:1 AFR. Which is good enough for a stage I upgrade with SE slipon's. Don't know if it is good enough for a stage II upgrade or a stage III upgrade. AND, the XIED/VIED's only work while the bike is in close loop mode which is low to mid RPMS. If your cranking a lot of high RPMs the XIED/VIED's would not be the way to go. Another option are the wide band 02 sensors, which is probally the route I will take if the XIED's won't be enough for STAGE II or STAGE III.
But I'd also say that if you are in the higher RPM range, you are moving a lot of air past the engine and cooling is less of an issue.
I could be wrong, but in a couple of years of being on the forums, I've never seen a post that said something to the effect of "my engine burned up". ETMS activated, yes, but no engine damage - certainly not while riding in higher RPM ranges
Not to rain on the parade here, but why would you combine a Fuel Pak at around $230 with XIEDs around $100 to have a mixed system when you could buy a single, more robust tuner with future capability for about the same money? Just sayin' ..........
You mean the same "engineers" who have been agressively developing the same basic air-cooled, pushrod, 45*, odd fire, V-twin for over 100 years, and it still has mad deficiencies, Yeah I'm pretty confident in my demonstrated abilities on this one. I've swapped the parts, I've tweaked the tunes, I've witnessed the AFR effects via data logged O2 feedback; done it, seen it, and earned the Tshirt. Why's it got to be an HD engineer or technician, or a Dyno Master to have credibility with so many people. These bikes are marginal quality production machines marketed as premium technological marvels of engineering on the premise of a hokie biker image. They are manufactured in the cheapest possible manner and as such there will always be room for improvement of components and systems.
Trust me, no MoCo engineer is going to tell you that the Delphi system is able to adjust for different components other than OE. The system is specifically designed to accommodate conditions, temps, slight variances in fuels and meet EPA standards, it is not in its design to accommodate or adjust for different components.
Having dyno tuned several thousand bikes over the years and being directly involved in development with several different EFI tuning products, EFI is something we work with first hand all day every day.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Explain this to me. Knowing that an O2 sensor's job is to read the amount of oxygen and send that to the ECM for adjusting air/fuel ratio. So, when you change the exhaust system out, why do you need a tuner and dyno tune to get the air/fuel ratio right? Why don't the O2 and ECM take care of it?
Thank for your thoughts.
David
David
Fair enough. Like I already explained that's just how it was explained to me. My mustang is dyno tuned and my a/f is 12.8-1 and it pulls like a Mac truck. Bikes may be different. I don't know for sure. And if it 2 resistors that's fine. I haven't done it. I merely quoted the tech I spoke too. His explanation sounded reasonable.
It is for this specific reason we are limited with how rich (or lean) we can go with closed loop calibrations in the first place with narrowband sensors, however if they are used within their limitations work very well.
OK guy's, I'm new to Harley so help me out. I have an 02 Electra Glide which just received 95 cylinders, new cams, dynojet kit and Vance/Hines Ovals. She runs good, little loud and choppy but the exhaust is showing a lot of black soot, and she feels like she's loading up when you let off the throttle. My feelings is she's running to rich but the lead harley mechanic said no just by zipping around the block. I want to install a wide band O2 system on it to monitor the AFR at ideal, cruis and wot. and make changes as needed. For a carburated bike I was looking at 14 at idel, 14.2 at cruise and 13.6 at wot. any input on that? also I'm going to install the O2 sencer on the front exhaust pipe 16 or so inches from the head, will that give me the correct reading.
Any help is needed
thanks
Any help is needed
thanks
