Need Amp Suggestions
Old 10-04-2011 | 02:05 PM
Paulster66's Avatar
Paulster66
Got to luv the Knowledge here. I am leaning on Keeping the 2 ohm J&M's and adding the J&M 4 channel, any suggestions on a good set of 5x7 at 2 ohm that will fit in the Harley Speaker lids for the rear?
Old 10-04-2011 | 02:17 PM
1sweetglide08's Avatar
1sweetglide08
Originally Posted by 2004Sierra
The RF PBR300X4 WILL NOT work with 2 ohm speakers.
I wanted to use Polk MM691 speakers but they are 2.7 ohms. I called Rockford Fosgate and thet said to only use 4 ohm speakers with the PBR300X4.
I'm running a set of titan hertz 6.5 inch speaker in my fairing and they are 3 ohms... bad or ok ????? The Polk Audio db691 are 4 ohms.
Old 10-04-2011 | 03:02 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
I'm running the Hogtunes 40.4 amp. It has 4 channels at 40 watts per. I got pulled over by a cop a couple weeks ago for having my stereo up too loud. I figure it's putting out plenty of power.
Old 10-04-2011 | 03:52 PM
2004Sierra's Avatar
2004Sierra
The guy I spoke with at Rockford Fosgate told me not to run the 2.7 ohm Polks with the PBR300X4. He said to only run a 4 ohm speaker.
How do the 3 ohm speakers sound?
Do you get any weird activity out of the speakers?
It may be OK to run the 3 ohm speakers, I am just passing along what the guy at Rockford told me.
Old 10-04-2011 | 03:57 PM
Harleypingman's Avatar
Harleypingman
Check-out the package that those speakers come in; it probably says "4 ohm compatible;" at least the MM 2.7 impedance speakers I saw on the shelf of a local car audio shop said so, but I don't recall if they were 6.5" or 5x7 speakers which are both rated as 2.7 impedance.
Carl
Old 10-04-2011 | 04:26 PM
bigdaddy33's Avatar
bigdaddy33
I just got a 2010 RG with a stock Satellite radio and amp and speakers I think. With the 16" windshield I can pretty much hear it at highway speeds, although I'm sure it would be way better with a better amp and speakers.
Curious though, if I do go for an upgrade to one of the suggested amps/speakers, will I be able to hear the radio if I put the 5" windshield back on?
Old 10-04-2011 | 04:48 PM
sublime_ac's Avatar
sublime_ac
You will be VERY happy with that J&M four channel, I am running the Arc KS125.4 which is the same amp but uses standard RCA jacks / power blocks instead of pigtails. The J&M will be easier to install.. Installing the Arc is difficult to say the least. Both amps produce an enormous amount of clean power and running 2Ohm speakers it will SLAM...
As for the 5x7 lids.. Forget those.. Either run a set of lower fairings and put some 6.5" or 7" speakers in them or look at the 6x9 lids from Yaffee and Kuryakin... You can get Infiniti Kappa 693.9i's in 2Ohm...
http://www.amazon.com/Infinity-Kappa.../dp/B001HL0UAG
Old 10-04-2011 | 04:55 PM
Beach's Avatar
Beach
+1 on the Jl audio, I have the xd400 and it fits inside the fairing. It pushes 2 audison 6.5 and 2 jlaudio 6x9's with no issues at all!
Old 10-04-2011 | 04:59 PM
sublime_ac's Avatar
sublime_ac
Would love to see some pics of that
BTW - Arc Audio has some new four channel amps...
Old 10-04-2011 | 05:21 PM
sublime_ac's Avatar
sublime_ac
FYI The new Arc four channel is the XDI 804.. It is three inches shorter, .4 inches taller and .7 inches deeper than the KS125.4... I think the .4" taller could be a deal breaker for the batwing install. It'll certainly work with a roadglide.. I might have to try mocking one up to see if it'll squeeze.. if it wasn't so much work to route cables and such for the KS125.4 I'd have already gone down to the Arc dealer and done it.
