Stripped allen head Help.....
Old 10-03-2011, 11:09 PM
bagman1's Avatar
bagman1
bagman1 is offline
You can get some anti-cam out fluid, they sell it at sears and tool dealers should have it too. Just a dab on the head increases torque grip by 400% and that **** works. Kimball-midwest sells it too. It may not help you tonight though.
Old 10-04-2011, 03:34 AM
Northside's Avatar
Northside
Northside is offline
I have removed countless socket head cap screws with turned out heads in my job. The best way I found and never had fail is to use a ballbearing! First spray some penetrating oil onto the screw. Aerokroil works best. You put a ball bearing on to the socket head and whack it with a hammer. The impact tends to loosen the screw and will swage enough material back into the socket that an allen wrench will fit tightly again. Make sure you use a perfect allen wrench. If the end is boogered up use either a new one or grind the end till its good. Use plenty of water to keep the wrench cool as you grind it. If the allen wrench slips right into the socket whack it again until the allen wrench needs to be tapped with a hammer to go in. T handles or hand held impact drivers work best. Now give it a twist and the screw should turn right out. I'm serious I have done this for over 30 years and never had to drill one out.
Old 10-04-2011, 08:01 AM
X Iron Butt's Avatar
X Iron Butt
X Iron Butt is offline
I did the same thing last week. Took a 21/32 drill and slowly drilled the head until I could drive the bolt through with a drift punch breaking the head off. The trick was to not drill all of the way through as it is aluminum after you go through. Do not hit the drift hard, as you get closer to the screw shank it will break off with just a light hit and you won't distort anything. Took about 5 minutes. You can look at the new screws you should have bought to get an idea of how deep you need to go. The first part of drilling goes quick until you get to the bottom of the hex. Second fork came loose right away.
Good Luck
Old 10-04-2011, 10:34 AM
HalfFast's Avatar
HalfFast
HalfFast is offline
Tap the head of the bolt with a ball pien hammer. The allen top will close back up enough to get your wrench into it. The tapping will also help loosen your bolt if it is siezed.
Old 10-04-2011, 12:08 PM
rg_dave's Avatar
rg_dave
rg_dave is offline
Tap the head with a hammer. Try using a metric that is slightly larger than the old allen and drive it in. You need to use an impact wrench so that it doesn't spin.
Old 10-04-2011, 03:26 PM
BBStacker's Avatar
BBStacker
BBStacker is offline
The bolt the op is referring to is on the bottom of the fork and about 1/2" - 3/4" down inside and not exposed. He couldn't hit it with a hammer if he had to. Although that is a good idea.
Old 10-04-2011, 05:50 PM
fxstbharley2008's Avatar
fxstbharley2008
fxstbharley2008 is offline
Thumbs up Got it out!
Guys thanks for all the suggestions.
I tried to use an easy out BUT it broke in there (OH NO).
So next I tried to use the impact driver with a straight screwdriver bit. The bit was a bit longer then the screw head so I tried to chisel a place for it.
I think the impact driver helped but did not get it out.
So I put my drill to it and made the allen hole a bit bigger
Then I hammered my larger tork bit in to the allen head and got my wife to hold the leg, used my 1/2" ratchet and it came loose - YES.
Thanks again!
Old 10-04-2011, 05:57 PM
BBStacker's Avatar
BBStacker
Thanks again!
Glad to hear you got it taken care of.
Old 10-04-2011, 06:38 PM
CSP067's Avatar
CSP067
CSP067 is offline
Great advice in this thread ... I learned a lot from all the suggestions! And glad some of it worked for the OP.
Old 10-04-2011, 07:50 PM
Invictys's Avatar
Invictys
Invictys is offline
Nice ideas here on how to extract a stripped bolt in a hard to reach place where an extractor might not be viable. Thanks!
Quick Reply: Stripped allen head Help.....
