SG LED Accent Lighting Suggestions
Old 10-06-2011 | 09:21 PM
Deuce Bigelow's Avatar
Deuce Bigelow
I used Custom Dynamics Hyper strips and wheel lights on mine..
no problem sticking them to the back of the calipers.. had them on my last two bikes and they never come off... ever!
Old 10-06-2011 | 10:45 PM
streetglide44's Avatar
streetglide44
Ok, here's where I put them. 1 on each side of tank, 1 on each bottom frame rail, 1 on each saddlebag rail, horn, air cleaner, under seat, rear fender under skirt, 1 on each side under front fender, 1 under cripple trees. 240 Leds. Prep with alcohol, use 3m tape under fenders to secure wiring. Wire to auxiliary switch on dash. It shines a full lane both sides of me. "Can you see me now?"
Old 10-07-2011 | 06:26 AM
fenderzig's Avatar
fenderzig
I bought a 180 light kit from Joe Florida on ebay for my Street Bob. I put them on each side of the front wheel and rear wheel. I put strips under each side of the tank, behind the AC and the horn, on each side of the frame rail, and across the front of the frame. There's not much space under the seat of a Street Bob so I had to manipulate the wires somewhat but got it to fit.
Here's a pic:
Old 10-07-2011 | 06:36 AM
dbell66253's Avatar
dbell66253
I used Joe Florida on both of my bikes, and have also used them on about a dozen other bikes I've done for friends. Clean area with alcohol, if you're a novice just follow instructions, Joe Florida is very good in price and service.
Old 10-07-2011 | 04:36 PM
1sweetglide08's Avatar
1sweetglide08
Here's a pic:
Nice job and having a remote to turn them off and on is also great. Stand back and change the colors with the remote and people sure will notice.
Old 10-07-2011 | 09:13 PM
2004Sierra's Avatar
2004Sierra
I used Custom Dynamics green lights with the breathing/3 strobe/ 4 levels of brightness remote.
Caliper lights on the front wheel, pod under upper frame to light up front valve cover.
A strip in the horn cover, strip under the air cleaner, two long strips under the tank. Two 6 led pods under seat to light up rear cylinder.
Two 24 led strips up inside the edge of the rear fender to light up the rear wheel.
I first installed the rear wheel lights on the bag rails. I hated being able to see the reflection of the lights in the chrome mufflers, plus they did nothing for lighting up the wheel.
I moved them under the fender edge and it really lights up the chrome rear wheel. It matches the brightness of the front wheel lights.
To me led's look much better installed in such a way that it is difficult to see where the light is coming from. jmho
Try to install them at night so you can try different locations for the best effect, before final attachment. It amazing how a couple inches one way or another will dramatically change the effect of the lights.
A little extra time with the install will make a huge difference in the finished look.
I have seen some terrible looking led installs, take your time and you will be much happier with the results.
Old 10-07-2011 | 09:25 PM
Amenraa's Avatar
Amenraa
Thanks for all the info guys. I appreciate the photos as well. Gives me a good indication of the final look.
Keep em coming as I still don't have the kit and have time to dream and drool.
clolson
02-26-2016 02:34 PM
Toliverpeterson
12-24-2015 08:53 AM
Colorido
07-20-2014 07:02 AM
kjkustoms
01-26-2013 04:55 PM
pistol_pete10
02-24-2007 09:15 AM
Quick Reply: SG LED Accent Lighting Suggestions
