Cam shim
Old 10-01-2011 | 07:02 PM
sg34's Avatar
sg34
Default Cam shim
Hey guys I have another question.I tore my 2010 SG apart yesterday to put in my cams I ordered ,doesn't look like they are gonna be here until atleast Monday.So anyways I went to dealer to get gaskets and o-rings and figured I would get all the shims while I was there they only had the .130,.140,and the .150.Mine had the .130 in it when I tore it apart ,my question is how would you possibly have to put a different size in it? It just doesn't make sense unless I am missing something ,there is a shoulder on the cam and I'm using the same sprocket bolted on it so the distance from the back of the sprocket to the shoulder on the cam would have to be approximately the same width.So I'm just thinking if I took a .130 then it should be good to go back,of course I will check when cams get here. Thanks guys
Old 10-01-2011 | 07:24 PM
Biggzed's Avatar
Biggzed
I've swapped several sets of cams for myself and other people. I've had to use a different shim on about half of them. In one case we had to shim a set of SE255's. On the other hand, I didn't have to shim when I went from stock cams to HQ575's. I had to shim when I went from HQ575 to TMan 590's though. I'm guessing it's just a matter of manufacturing tolerance variances.
Good luck on your project.
Zach
Old 10-02-2011 | 06:04 AM
Reaper22's Avatar
Reaper22
I put in the se 255's and went from .110 to .130..Your right tho don't make sense but your talking thousand's here so that's why we shim to get proper alignment of the sprockets..
Old 10-02-2011 | 08:38 AM
CURTYS06FLHX's Avatar
CURTYS06FLHX
Had to shim a set of 204s when i put them in my 06 Street Glide.
Old 10-02-2011 | 08:51 AM
Notgrownup's Avatar
Notgrownup
I had to go from .110 to .120 i think in mine....was just 1/10th...Depends on the cam and the way it was machined. You will have to wait until you have the other cam in to know for sure with the feeler gauges....only way 2 no fo sur....
Old 10-02-2011 | 08:56 AM
atrain68's Avatar
atrain68
The variation could be anything, but the good news is measuring and picking a shim is not difficult.
Old 10-02-2011 | 08:22 PM
V2Evo96's Avatar
V2Evo96
I went from a .120 with OEM cams to a .130 with S&SS 551 EZ starts.
Old 10-02-2011 | 09:09 PM
cruzmisl's Avatar
cruzmisl
difference in mine was 30 thou. Had to go up two sizes.
kllrvet
Milwaukee Eight (M8)
07-02-2017 07:19 PM
stan60
07-26-2012 09:45 AM
jaysonL
Exhaust System Topics
07-19-2012 10:18 PM
myy2khog
03-07-2012 07:05 AM
neonhomer
19
04-04-2009 11:04 PM
Quick Reply: Cam shim
