Clutch Cable Replacement
Are there any threads to show how to replace a clutch cable on a 2008 HD? Mine is leaking where it connects into the transmission and needs to be replaced.
I was thinking of doing a diamond braid or something like that. Any recommendations on a clutch cable to use as well?
-Get a service manual if you don't have one. This is definitely something you can do in your garage.
-Get the tools needed if you don't have them. You will need a good set of snap ring pliers to do this job.
-Get the cable. I agree with you to go back with a good braided cable. I did that on my old RK.
-Change the cable. Of course they come in different lengths, so get the right length.
To search topics on this forum from a search engine, simply type in hdforums.com followed by your key word or a very short description. You may also put the description in quotes if you want to search for that exact phrase.
If you are firm about a new cable, Magnum makes nice looking cables but the outer clear coating is fragile and easily cut. When I did my bars, got a +2 from Barnett in black vinyl. HD cables are rather pricy like everything else they sell.
Oh and the Barnett are made in the USA.
Changing a clutch cable on a Touring bike is a pain in the *** and labor intensive. Requires the front fairing piece to be removed, the exhaust removed, the right transmission cover removed in addition to disconnecting the cable at the lever and the mechanism inside the transmission cover and unscrewing the cable housing from the cover. Then you have to get the old cable out and fish the new one in, get it positioned properly and remount everything.
If it is leaking just around the housing where it goes in the side cover, then most likely it is an o-ring. Still requires the exhaust to be removed and the transmission side cover removed, but the cover can be unscrewed off the cable housing once the mechanism inside is removed with a large snap ring pliers. A service manual is pretty much a must.
When to replace clutch, brake, throttle, and idle cables
I've got a 2005 Deluxe with approximately 14,500 miles. I've got no problems other than some cracking and peeling of the black outer coating which covers the actual cables. This is around the head bracket and I just wrapped it in black electrical tape to keep moisture out. Was thinking of replacing all of the cables at one time, but that's sorta pricey. Should I really even consider replacing or just wait until I start having some minor problems??????
