Installing a hidden antenna
RE: Installing a hidden antenna
fairing is pretty easy. 6 screws that hold the side deflector wings, 3 screws on the windshield, and a couple of hidden ones near the frame neck. disconnect the headlight and yo're good to go.
can say much for the antenna, but height does matter sometimes in picking up them distant stations on the road. go sirius, hide the antenna under the fairing, and you can listen all the time, anywhere on the road.
[IMG]local://upfiles/12616/3743A0F7C75342ACAE2D59CDB81BEBDC.jpg[/IMG]
There are three windshield screws and 4 inner fairing torx screws that will let the outer fairing come off. Put towels or rags over the fender and passing lamps so you don't damage paint.
After you have the outer fairing loose, you need to disconnect the headlight wire to completely remove it.
As far as the antenna goes, just unplug the factory one and plug in the other and mount it securely with wire ties, 3M tape, etc.
"Dakota Digital" is a powered antenna that requires you to tap into a hot wire. It mounts to the inside of the outer fairing with 3M tape. With the "Tune Trapper", you can just wire tie it to some of the wires under the fairing.
I have experience with both of these. Niether will be quite as good as the factory whip, but both are adaquate unless you live way out in the boonies.
Regards,
Bill
Regards,
Bill
Received 7,821 Likes
