EZ-UP center stand
Old 09-30-2011 | 04:49 PM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by mjb765
Nothing in this world is perfect...but after going over all the same places that my 06 used to wobble, my '10 & '11 do not wobble even at a higher speed. Haven't found the need for the True Track on the new frame yet.....
+1 .... The new frames have definitely taken a substantial amount of wobble out!
Old 10-01-2011 | 05:52 AM
dnitram's Avatar
dnitram
I've only had problems when we rode two up and didn't have enough air in the shocks. Once I fixed that, there have been no issues. I also found out the hard way to follow their instructions about leaning to the right when putting the stand down while you're on the bike. Ouch!
Old 10-04-2011 | 11:58 AM
cmc seabee's Avatar
cmc seabee
Default EZ-UP center stand
Thanks for all the replies. That's what I like about this forum, you can always get help and advice without paying the dealer over $100.00 per hour.
Old 10-04-2011 | 12:53 PM
Geoff's Avatar
Geoff
My Rivco stand has no clearance issues. The Rivco is better constructed than the Wheeldock. Also, it raises the rear wheel off the ground. This makes cleaning and checking air pressure easier.
Old 10-04-2011 | 01:46 PM
dbird's Avatar
dbird
Removed mine,could not go up ramp on lift table.
Old 10-05-2011 | 05:47 AM
dbell66253's Avatar
dbell66253
The construction looks to be similar, except I like the chrome bottom on the Rivco, my EZup also lifts the rear wheel off the ground, look at my sig pic.
Old 10-05-2011 | 09:31 AM
nivensid's Avatar
nivensid
Default Ez up
I put mine on the other day, took a few minutes to get used to it but after the first time it was all good. Little awkard using the plywood under the stand to lift the back wheel, maybe because I had on the wrong shoes. Happy with it and will use it often.
RogFel
2014-2023 Touring Models
26
03-20-2015 09:03 PM
cmc seabee
12-28-2011 02:49 PM
mcain49
12-27-2010 11:52 PM
tx-skydiver
10-28-2010 07:08 PM
fasteddiee122
05-11-2009 10:49 PM
Quick Reply: EZ-UP center stand
