progressive shocks
Progressive shocks are much better than Harley stock shocks, but, there is a better shock than the progressives. They are called "Works Performancel "Steel Trackers DRS/ARS " and they perform alot better than progressive 440's. They are awesome shocks but the down side is they are more expensive!
There is a night and day difference between the 440's and the Works Performance shock. I am not saying that progressive shocks are not good because I have progressive shocks on my current bike and they are alot better than stock shocks! But the Works Performance shock rides like a "Cadillac" compared to the Progressive shock. This is my opinion after having both shocks on my bike.
Either shock is going to be better than the Harley stock shock.
I hope this information is useful to you. Ride safe!
John
I have heard as many complaints about the 440s as I have heard praise how good they are, Was up in the air on what I was going to do, Started looking around and found Works Shocks and though I would call them to see what they would recommend after talking to them for about 10 min went ahead and ordered them. The one thing that I liked is they have a Dual rate spring and threaded preload so once you get the bike set your done no going back to adjust the pre load like on the progressive.
They also ask how much you weigh and you riding style said they custom make them for you ( don't know how much of that is sales tool) Guess it will be spring before I can try them out.
Charlie
Charlie
ORIGINAL: roadglide65
Works shocks still have variable preload for varying riding conditions.
I have heard a lot of good things about Works & I may try a set of Steel trackers myself.
~John
ORIGINAL: screemnjay
I've installed a number of 440's, and depenent on pre-load they all will clunk, and again, they have no rebound damping. If you want a good riding, high performance shock, the Works are FAR superior to the 440's.
The works are not air shocks I take it?
What length would I order if I want to drop the rear an inch?
Also, we ride 2 up quite a bit and with my wife on back we weigh in around 450lbs. Would I be getting into a bottoming out problem by going away from the air shocks? Right now with the stock units I never bottom out.
Thanks in advance....
I have an '05 RK Classic with the stock air shocks and was thinking about the 440's also, but now I'm interested in the Works units from what I'm hearing outta you guys. I have a couple questions.....
I just called Works to see about ordering a set but they where closed. They must be closed for Thanksgiving because I called during normal business hours.
~John
ORIGINAL: jmorton10
~John
~John
Yea they do have a threaded preload but if i understood him right the only thing it will do is raise or lower the ride height. Guess i need to get them in my hands first to be able to talk about them.
Charlie
Like John said the stock shocks are 13" they have two differant spring rating 400# and 500# the best thing I can tell you Is to call them and tell them what you want and they will build them for you. http://www.worksperformance.com/
Look under Street Bikes and then the Street Trackers.
Charlie
Charlie
