Deer Warning Device
Are the devices supposed to make the deer freeze in their tracks or make them run off? If its the later the problem is you can't control which direction they will go. Like others have said, its more common sense defensive riding than anything, but deer are like drivers who blow the red light on you, you never can predict when that will happen. I try to stay off the road at dusk, but if I'm caught in a rural area around that time I ride slower and with increased awareness.
I don't blame the damn deer, we killed off all of its predators and upset the balance of nature. In my area deer are more unpredictable because constant logging and clear cutting is going on. The two times I had encounters with deer was in broad daylight, not pucker moments, but a couple to a few seconds away from having a unscheduled meeting with Bambie.
Zoo, +1 on what agapsdiver said. I have seen the Hornet device work more than once while riding. IMHO, the main advantage with having an electronic device (NOT an "air-activated" one, I don't think they work) is that the deer will hear you coming from a good distance. This "heads up" can, not 100% of the time, but can....prevent a case of the deer being "spooked" by your ride and jumping out in front of you.
As many folks have posted on this subject, you still need to slow down and use common sense when you are in a high threat area.
