Center Stand
Old 09-28-2011 | 02:51 PM
DXHD $100's Avatar
DXHD $100
You should look at the Wheeldock EZ-Up stand. It is, by far the easiest to install ( took ten minutes literally ) and to use center stand on the market in my estimation and I've been riding for over 45 years. Check out their site. Do a search of the Forum and you will get a lot of positive feedback. I had the HD Stand and it was very difficult to use, it rattled on the stock exhaust also. I'm 6'2" and 260 lbs ... my better half, well lets just say she's better than half! I can sit on the bike with her on the back seated and put the bike ( a 2009 FLHTCU ) up on the stand while I'm seated with minimal effort. I can also load the bike on the stand, have the ol' girl hop on, get comfy, then pop the bike in gear and ride away. Here's a link to their site. I would highly reccommend their stand. Good Luck.
http://www.wheeldock.com/prod_EZ.shtml
Any clearance issues on speed bumps, or extreme curves?
Old 09-28-2011 | 03:07 PM
dbell66253's Avatar
dbell66253
Originally Posted by mjb765
EZ Up Center stand...easier to get on it than the HD and drive right off.
+1, I had an EZ up on my 07, and I also have one on my current bike, very easy to install, works great.
Old 09-28-2011 | 03:11 PM
shortride's Avatar
shortride
Originally Posted by grbrown
It's known as a display stand, I have one on my Glide. It is not intended to lift a wheel off the ground and only works on a level surface, but I love it. Works fine for most occasions and the feet can be adjusted so it is easy to use. Also helps servicing at home, to keep the bike upright. Does everything I want of it except help me get a wheel out of the bike, but I have a lift for that.
I would love to have a display stand on my '09 Ultra Classic but I understand the display stand will not mount if you have an oil cooler. I had one on my '03 UC and liked it a lot.
Old 09-28-2011 | 04:58 PM
Uncle Larry's Avatar
Uncle Larry
Just got back from spending 10 days down in the Smokies, did the Dragon, Cherohala, and all the "Great Ride" roads and only had minimal clearance trouble in and out of some of parking lots. They tend to create some exaggerated angles between the roadway and the parking lots. I pushed the scooter ( 2009 FLHTCU ) hard double up and encountered no problems.
Old 09-28-2011 | 05:00 PM
Uncle Larry
The Display stand WILL NOT FIT 2009 or later scooters with or without an oil cooler.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old 09-28-2011 | 06:23 PM
ucommbxny's Avatar
ucommbxny
have the center stand on my 08 use it all the time
Attached Thumbnails Center Stand-misc.-photo-s-023.jpg   Center Stand-2011-misc.-photo-s-018.jpg
Old 09-28-2011 | 07:33 PM
ChristoHD's Avatar
ChristoHD
EZ - get the EZ. :-)
Old 09-28-2011 | 07:41 PM
AbnMP13's Avatar
AbnMP13
I have the HD stand and have no issues; easy to install for me.
Old 09-28-2011 | 08:13 PM
m361's Avatar
m361
+1 to whatever number have already recommended the ezup. I have a SG so its a little lower than other touring bikes. Only clearance issue I have had at the end of my driveway. The concrete curb sticks up about a half inch above the concrete driveway so if I go over it too fast it scrapes just a bit. As long as I remember to go over it slowly its not a problem.
Old 09-28-2011 | 08:32 PM
mcain49's Avatar
mcain49
Another vote here for the EZ Up stand. Less than 10 minutes to install on my Ultra and bike goes up on stand with very little effort. Like the ride off part as well and it makes servicing (oil changes) more convenient. Nice accessory.
Quick Reply: Center Stand
