Big Bore... Forged Pistons vs. Cast Pistons
Im wanting to do a BB this winter and cant decide on the 103 or the 106 or 107. I intend to have the heads worked but dont want to have crank work done. I like the idea of the lighter cast pistons but the biggest I can find are 3-7/8" (103). On the other hand, I think while Im doing it, I might as well go to a 107 but again, I cant run cast pistons. What are the pros and cons to forged pistons and cast pistons?
cast, imaging pouring fluid metal into a cast- you take it out clean it up- 'piston'
Forged- similar process but under pressure- there are no voids, inconsistencies in density, metallic structure more stable.
it is possible that more 'pure' alloy will be used in this process.
so stronger, more solid, may weigh more, but higher strength allows more weigh relieving.
possibly better quality control material and machining- just because it is a premium cost product
for your build find a system that works with your bike ( weight) gearing, riding style, wishes ( MPG/ HP/Torque/ reliability and service life etc) and will not require re-engineering everything else to match it.
Mike
Mike
If you could find the proper size, a Hypereutectic piston would be the best compromise. They have a higher Silicon content and expand much less than cast or forged pistons do. That being said, you can fit them with tighter piston to wall clearances for a better seal. Google it, they explain it in a lot more detail than I can.
Received 49,955 Likes
Unless you're getting really exotic ( High compression ratios ) there is no need for a forged piston. There have been major advances in quality over the past several years. Another factor to consider is noise. Forged psitons can be / are very noisy but are stronger ... the question is how much strength do you need?
