New Droid App for V Twins
Old 10-04-2011, 08:22 PM
Bdhouse61's Avatar
Bdhouse61
Bdhouse61 is offline
Originally Posted by threeten
pm me with an email address
pm sent, ,,,,,,thanks
  #162
Old 10-04-2011, 08:50 PM
Mntsnow's Avatar
Mntsnow
Mntsnow is offline
Great work again and nice to find it now on the Market
  #163
Old 10-09-2011, 09:31 PM
Bdhouse61's Avatar
Bdhouse61
Question
Well I am glad lots of the members are able to download and install this app......saw it on my buddys phone and it looks like a very good app.
Does anyone on here have the HTC Wildfire phone that was able to download and install it? I CAN'T FOR SOME REASON.....even my buddy has a HTC phone but another model and had no problem. Any help would be appreciated.....threeten thinks it has something to do with my phones resolution?
  #164
Old 10-10-2011, 08:19 AM
asahi1234's Avatar
asahi1234
asahi1234 is offline
Great app anything in the future.?
  #165
Old 10-10-2011, 11:10 AM
threeten's Avatar
threeten
threeten is offline
Yes, but I will be working on it at a much slower pace. It is a hobby and my work is demanding all of my time right now. I am open to suggestions on what should be added / improved.
I have a new version with the maintenance schedule that I am ready to release, but I have been wondering if it really has any value. It is kind of cool to look at, but I don't know if it is of practical use. In addition, all my information is based on 2009 touring models, because that is what I own.
A couple of folks have suggested a gas mileage log, but I think that may be beyond my ability. It is very complex to do calculations and store values, and there are stand alone apps for free that do this really well. I'll keep reading on it, but it won't be coming anytime soon, if at all.
I have been thinking about adding torque values, and the quick maintenance reference charts. Let me know what you guys think, you can always send me a pm or an email.
For the curious, the Android app market provides a lot of statistics. As of today, it shows a total of 551 installs with the vast majority of them on the Droid X.
ride safe
  #166
Old 10-10-2011, 11:30 AM
IzzoQuazzo's Avatar
IzzoQuazzo
IzzoQuazzo is offline
Retired Admin
Received 9,041 Likes on 3,711 Posts
Just loaded it. Really cool. Thanks
I also loaded a note pad App that can encrypt your notes. I have put my start code there and named the note after my bike's nickname. That is then encrypted and I need to enter a password in order to read it. Here's the note App:
https://market.android.com/details?i...=search_result
I'm considering putting this as a sticky subject but since it really applies to all HDs with security, I think it belongs in General HD Chat and not just in Touring.
Comment if you like. I'll decide tomorrow.
Izzo
  #167
Old 10-10-2011, 12:49 PM
z71_fourwheelin's Avatar
z71_fourwheelin
z71_fourwheelin is offline
Great App. Also like how it has the quick link to the forums.
  #168
Old 10-10-2011, 01:17 PM
Dennis Murawski's Avatar
Dennis Murawski
Dennis Murawski is offline
Default Year specific DT codes
Thank you for the really cool app. I downloaded it and it works great on my Droid X.
I have a 2007 FLHT and when I compared your DT codes to the ones in the Harley manual for the 2007, some are missing. I'm guessing that the DT codes vary by model year. In the future when you have more time than you know what to do with, ;>) you might want to have model year specific codes.
Thanks again for all your work.
Dennis
  #169
Old 10-10-2011, 04:21 PM
threeten's Avatar
threeten
threeten is offline
Separate editions for different models and years is the way to go, but I'd have to have some help. If anyone wants to type up the codes or quick maintenance reference for their model and year, let me know.
It is easy to plug the information in and only needs to be done once.
  #170
Old 10-10-2011, 07:22 PM
Dennis Murawski
2007 Harley Davidson Diagnostic Trouble Codes
(from Service Manual 99497-07)
DTC FAULT CONDITION MODULE
“BUS Er” (TSM/HFSM) Serial Data Open/High
B0563 Battery Voltage High (TSM/TSSM)
B1004 Fuel Level Sending Unit Low (Instruments)
B1005 Fuel Level Sending Unit High/Open (Instruments)
B1006 Accessory Line Overvoltage (Instruments)
B1007 Ignition Line Overvoltage (Instruments)
B1008 Reset Switch Closed (Instruments)
B1121 Turn Signal Will Not Flash (HFSM)
B1122 Right Turn Signal Open (TSM)
B1123 Left Turn Signal Short-to-Ground (HFSM)
B1124 Right Turn Signal Short-to-Ground (HFSM)
B1125 Left Turn Signal Short-to-Voltage (HFSM)
B1126 Right Turn Signal Short-to-Voltage (HFSM)
B1134 Starter Output High ((TSM/TSSM)
B1135 Accelerometer Fault ((TSM/TSSM)
B1136 Accelerometer Tip-Over Self Test (HFSM)
B1141 Ignition Switch Open/Low (HFSM) ONLY
B1141 Turn signals Will Not Flash (TSM) ONLY
B1142 Internal Fault (HFSM)
B1143 Security Antenna Short-to-Ground (HFSM)
B1144 Security Antenna Short-to-Battery (HFSM)
B1145 Security Antenna Open (HFSM)
B1151 Sidecar BAS Low ((TSM/TSSM)
B1152 Sidecar BAS High ((TSM/TSSM)
B1153 Sidecar BAS Out of Range ((TSM/TSSM)
B1154 Clutch Switch Short-to-Ground (TSM/HFSM)
B1155 Neutral Switch Short-to-Ground (TSMHFSM)
B2006 Radio Switches Shorted/Stuck (Audio)
B2007 Handlebar (Audio) Switch Shorted High(Audio)
Handlebar Mode Switch Shorted High(Audio)
Handlebar PTT/Squelch Switch Shorted High(Audio)
B2008 Handlebar (Audio) Switch Shorted Low(Audio)
Handlebar Mode Switch Shorted Low(Audio)
Handlebar PTT/Squelch Switch Shorted Low(Audio)
B2009 Handlebar (Audio) Switch Stuck or Open(Audio)
Handlebar Mode Switch Stuck or Open(Audio)
Handlebar PTT/Squelch Switch Stuck or Open(Audio)
B2010 Passenger (Audio)/PTT Switch Shorted High(Audio)
Passenger Mode Switch Shorted High(Audio)
B2011 Passenger (Audio)/PTT Switch Shorted Low(Audio)
Passenger Mode Switch Shorted Low(Audio)
B2012 Passenger (Audio)/PTT Switch Shorted Stuck or Open(Audio)
Passenger Mode Switch Shorted Stuck or Open(Audio)
B2013 Sidecar Switches Shorted High(Audio)
B2014 Sidecar Switches Shorted Low(Audio)
B2015 Sidecar Switches Shorted Stuck or Open(Audio)
B2016 Front Speakers Shorted(Audio)
B2017 Front Speakers Open(Audio)
B2018 Front Speakers Shorted to Ground(Audio)
B2019 Front Speakers Shorted to Battery(Audio)
B2020 Rear Speakers Shorted(Audio)
B2021 Rear Speakers Open(Audio)
B2022 Rear Speakers Shorted to Ground(Audio)
B2023 Rear Speakers Shorted to Battery(Audio)
B2024 Sidecar Speakers Shorted(Audio)
B2025 Sidecar Speakers Open(Audio)
B2026 Sidecar Speakers Shorted to Ground(Audio)
B2027 Sidecar Speakers Shorted to Battery(Audio)
P0107 Map Sensor Open/Low (EFI)
P0108 Map Sensor High (EFI)
P0112 IAT Sensor Voltage Low (EFI)
P0113 IAT Sensor Voltage Open/High (EFI)
P0117 ET Sensor Voltage Low (EFI)
P0118 ET Sensor Voltage Open/High (EFI)
P0122 TP Sensor Open/Low (EFI)
P0123 TP Sensor High (EFI)
P0131 Front O2 Sensor Low (EFI)
P0132 Front O2 Sensor High (EFI)
P0134 Front O2 Sensor Open/Not Responding (EFI)
P0151 Rear O2 Sensor Low (EFI)
P0152 Rear O2 Sensor High (EFI)
P0154 Rear O2 Sensor Open/Not Responding (EFI)
P0261 Front Injector Open/Low (EFI)
P0262 Front Injector High (EFI)
P0263 Rear Injector Open/Low (EFI)
P0264 Rear Injector High (EFI)
P0373 CKP Sensor Intermittent (EFI)
P0374 CKP Sensor Synch Error (EFI)
P0501 VSS Low (EFI)
P0502 VSS High/Open (EFI)
P0505 Loss of Idle Sped Control (EFI)
P0562 Battery Voltage Low (EFI)
P0563 Battery Voltage High (EFI)
P0603 ECM EEPROM Error (EFI)
P0605 ECM Flash Error (EFI)
P0661 Active Intake Solenoid Open (EFI)
P0662 Active Intake High/Shorted (EFI)
P1001 System Relay Coil Open/Low (EFI)
P1002 System relay Coil High/Shorted (EFI)
P1003 System relay Contacts Open (EFI)
P1004 System Relay Contacts Closed (EFI)
P1009 Incorrect Password (EFI)
P1010 Missing Password (EFI)
P1351 Front Ignition Open/Low (EFI)
P1352 Front Ignition Coil High/Shorted (EFI)
P1353 Front Cylinder No Combustion (EFI)
P1354 Rear Ignition Coil Open/Low (EFI)
P1355 Rear Ignition Coil High/Shorted (EFI)
P1356 Rear Cylinder No Combustion (EFI)
P1357 Intermittent Secondary Front (EFI)
P1358 Intermittent Secondary Rear (EFI)
P1475 Exhaust Actuator Position Error (EFI)
P1477 Exhaust Actuator Open/Low (EFI)
P1478 Exhaust Actuator Shorted (EFI)
U1016 Loss of ICM/ECM Serial Data (Instruments)
U1016 Loss of Serial Data(Audio)
U1016 Loss of ECM Serial Data (TSM/HFSM))
U1064 Loss of (TSM/TSSM) Serial Data (EFI)
U1064 Loss of (TSM/TSSM/HFSM) Serial Data (Instruments)
U1097 Loss of Speedometer Serial data (EFI)
U1255 Missing Message at Speedometer (EFI)
U1255 Serial Data Error/Missing Message (EFI)
U1255 Serial Data Error/Missing Message (Instruments)
U1255 Serial Data Error/Missing Message (TSM/TSSM/HSFM)
U1300 Serial Data Low (EFI)
U1300 Serial Data Low (Instruments)
U1300, U1301 Stalls, then Starts(Audio)
U1300 Serial Data Low (TSM/HFSM)
U1301 Serial Data Open/High (EFI)
U1301 Serial Data Open/High (Instruments)
U1301 Serial Data Open/High (TSM/TSSM)
U1302 Infotainment BUS Shorted Low/High(Audio)
U1306 Infotainment BUS Lost Communications with Hands free Phone Module(Audio)
U1307 Infotainment BUS Lost Communications with CB Module(Audio)
U1313 Infotainment BUS Lost Communications with XM Module(Audio)
U1314 Infotainment BUS Lost Communications with Navigation Module(Audio)
U1317 Infotainment BUS Lost Communications with High Output Amplifier(Audio)
Quick Reply: New Droid App for V Twins
