FLO Stainless Steel Reusable Spin-On Oil Filter ??
I am entertained by the self styled "engineers" who know more than the factory guys who offer an UNLIMITED mileage warranty using the 5 micron filter. Cold oil flow? Make your choice between briefly unfiltered oil PREVIOUSLY filtered to 5 microns vs full time oil flow ALWAYS cleaned to 30 microns. Even for $67, I can buy 4 Harley filters before I break even, and have to deal with the cleaning solvent along with the dead oil from the change, Your money, your bike, do as you wish, but be alert for the snake oil salesmen, they survive by making the ridiculous sound reasonable. Buyer beware.
https://www.ecogard.com/truth-about-...icron-ratings/
There are a lot of very valid personal reasons folks can come up with for going or not going the reusable route but, filter performance isn't one of them.
The difference between the nominal micron rating and absolute micron rating (not to mention efficiency rating) of oil filters has been beaten to death on this forum and elsewhere:
The ad says " catches items down to 35 microns."
Harley's EVO filter requirements were 30 microns per single pass, the Twin Cam specs all the way down to 10 microns...So No Way!
(I once called Fram direct on their very cheap 6022 $6 filter and even that caught 30 microns!)
Sorry, but not for me....
Yes, but it will evaporate the first time the engine comes up to normal temperature. Back, before jets, old time airplane engines were not much different than Harley engines. Airplanes parked outside in cold climates used gasoline dilution in the oil just at shutdown so the oil wouldn't be thicker than honey at the next start. The gasoline thinned oil allowed an easier start and cold oil flow and the gasoline evaporated as the engine warmed up. Any solvent left in the filter element will only slightly thin the oil temporarily, but even then the oil will be thicker than when it is at normal operating temperature. I don't know what Harley would say, but 80 years of aviation experience says it is a non-problem.
But I agree with your point about a small amount of solvent getting into the oil, it isn`t going to hurt a thing.
If someone was really concerned about solvent contamination, just rinse the filter with oil after cleaning to rinse any cleaning agent off the filter.
But, I`ll just spin on a Wix and be done with it.
eighteight (11-21-2019)
I wouldn`t even consider a DIY oil change on the road, not on a car or motorcycle, impractical would be an understatement...
Read your article and still have the same question re your last statement. Why not just roll up a piece of window screen material and put that in the filter can if "filter performance" isn't important? Ultimately, we as consumers, have no idea if the filtration claims of the factory filter and the reusable one used the same criteria. I fail to see the LOGIC in consciously deciding on a filter that claims it ALLOWS particles SIX TIMES LARGER than the factory filter to recirculate in the engine. Again, your money, your sled, your choice. We all have OPINIONS.
Enough knowledgeable engine builders recommend the SS reusable filters to believe that filtration performance is not an issue. There are other valid reasons to use or not use a reusable filter but, again, filtration performance is not a proven one.
In the end, I agree. Believe what you want, use what you want, it's another fricking oil thread.
