I have an annoying squeak at idle. Sometimes it doesnt do it, but it seems to do it more when its cold. It almost always does it when holding the front brake down. Im thinking it might be a motor mount. Its coming from the transmission area.... The bike is an 01 Road King with 65k on it. Do these motor mounts go bad? Could it be anything else?
..at idle is where the motor does the most shaking...so check those parts that are moving the most..especially the entire exhaust system everywhere there is a connecting joint, or a clamp on it...and like Dawg said...could be a motor mount..check air cleaner assembly too, they can get loose...good luck
Check your rear exhaust/muffler hangers. Easiest and quickest way to check them is to have the bike idling and place your foot on each muffler in turn and see if the squeak stops. That was once my problem.
Check your heat shields too. If you have a rubber mallet, gently tap around fasteners in the area the squeak seems to be coming from and maybe you'll get lucky.
my bike had an annoying sound at idle to, as I went faster it got quieter...I got it to stop by telling her to shut up or get the f off....no more problem, not even a squeak...
