Hello all. Recently bought a 2011 ultra classic. The books says it has a cb radio. Does anyone no if this is the case or not. Have not hooked up the headset yet. But I would think if the cb was there it would come in over the radio right?
Thanks
The ultra does have a cb. You have to turn it on to activate it. You use the buttons on the radio faceplate to turn it on. adjust the channel and squelch. The owners manual will tell you everything you need to know about it.
Press the com button, turn the CB on. Play with the buttons, switches and hand controls. You can use the radio and CB at the same time. You will figure it out.
No need to read the manual.
