R/T/B Module doesn't work on Street Glide
If the Street Glide has a center mounted brake light the Auxilary RTB conversion kit will work, although it states that it is not intended for 04-Later models for the following reason.
"NOTE: Not intended for use on '04-later FLHX, FLHRS, FLTR or FLHTCSE models, '05-later FLSTN models or models equipped with Bullet Turn Signal Bar Kit P/N 68615-04 or 68617-04. If installed on these models, the system will function properly but will not meet the DOT minimum separation requirements for a red tail light to red turn signal."
That being said I've had one on my 09 Street Glide with no problems.
