LED aux lamps - condensation behind lens - normal or replaced?
Got a quick question....
I picked up my 2012 Limited a couple months ago and noticed recently there is condensation sitting behind the lens of both aux lamps. The LED headlamp is fine. Is this normal or something I should have the dealer check out and replaced under warranty?
Not normal. Is there a gasket behind the lens? Are you hitting them with high pressure water or air when you wash it? I am getting ready to put LED's in my front end so far no condensation with stock lights.
I do get some on the front fender light after washing. I am going to see if I can seal it up better.
Are the Aux lights LED, or just the headlight?
http://www.customdynamics.com/
When money allows, the next upgrade will be LED head light and passing lamps. I think I will go with Truck Lite for that. Much cheaper than HD and test show same performance, plus twice the warranty.
I guess you could always run a thin silicon bead around the lens seating area. Probably would have to break the lens to change the bulbs though.
As was said earlier, make sure the part #'s for both the Aux lights and the Headlight, are the new version with an (A) after the part #.
The older version without the (A) wasn't sealed correctly, if they're the older version, the dealer should warranty them out for you.
