Shimmy at 30 mph
Old 09-17-2011 | 02:10 PM
DISTURBEDCUSTOM's Avatar
DISTURBEDCUSTOM
Default Shimmy at 30 mph
I toticed a wobble at 25 to 35 mph and th front rim is bananced only thing i changed was front eim from 17 to 18 now i noticed the wobble
Old 09-17-2011 | 02:51 PM
DannyZ71's Avatar
DannyZ71
We need some details. Spokes or mags? Tubeless or tubes? wheel weights to balance?
First thing I'd check if they're spokes is all the spokes, both front and back.
Old 09-17-2011 | 03:01 PM
Jackie Paper's Avatar
Jackie Paper
Shimmy is not balance. Balance give you a up and down beat equally in the grips or rear seat of the paints. Shimmy or wobble is side to side run out that pulls the grips in and out of your hand or grinds the seat up into your butt. Assume you installed new tire. Could be that. Assume you had someone else do it. I would have them check it. There was a recent post were the person lost his front wheel. The installer had over torqued the axle cap. His description was I had a vibration, a slight shimmy and then the wheel came off. He was lucky to be still posting.
ChicanoRoadking07
04-12-2014 01:27 PM
BigDevil
02-02-2013 11:15 AM
Mr.Twisted
06-02-2012 01:42 AM
Griff012FLHX
10-02-2011 10:51 AM
eric91379
04-21-2008 07:43 PM
Quick Reply: Shimmy at 30 mph
