How to remove electrical terminals?
Old 09-15-2011 | 11:18 PM
gred-04's Avatar
gred-04
Default How to remove electrical terminals?
Also posted in the tech section, hoping someone has a trick to
remove the turnsignal/taillight terminals pins from the connector
blocks?
I see that HD references a snap-on tool but hoping someone
has done this with a pick or small screwdriver.
Would have to order the tool and the bike is apart and sitting.
Thanks
Old 09-15-2011 | 11:42 PM
mkguitar's Avatar
mkguitar
for most:
push pin forward in block, insert small screwdriver to depress tab on pin ( usually on top) pull pin back
mike
Old 09-15-2011 | 11:59 PM
BBStacker's Avatar
BBStacker
Originally Posted by mkguitar
for most:
mike
+1 or a stout paperclip, safety wire. Just make sure you have your service manual in case you forget what went where or at min. draw a diagram.
Old 09-16-2011 | 06:04 AM
fxstbharley2008's Avatar
fxstbharley2008
Just went to my dealer today - took my parts that needed to have the wires taken out of them watched my tech do it ( he did this for free) so push pin forward in block, insert small screwdriver from back to depress tab on pin ( usually on top) pull pin out
Front turn signals were not bad but the rear is different.
Ask you tech to do it. My Harley is also apart!
Old 09-16-2011 | 06:26 AM
kyote's Avatar
kyote
And when people say a small screwdriver.. Small as in a Jewelers Screwdriver.. "very small".....
Old 09-16-2011 | 09:23 AM
gred-04's Avatar
gred-04
Thanks guys for the tips. Another satisfied customer ...
I was trying to release from inside the pin, doesn't work too well like
that
Old 09-16-2011 | 10:38 AM
3/4 life crisis's Avatar
3/4 life crisis
Around here (in Indiana), Menards hardware stores carries a tool to do just that, less than $4. Works great!
Old 09-16-2011 | 12:13 PM
BackRoader's Avatar
BackRoader
Do a you tube search on this and you will find step by step video.
JoeN
Audio Systems
04-27-2014 02:27 PM
Da Butcher
07-23-2009 12:03 AM
Blues Guy
03-05-2008 02:29 AM
dustinw58
01-12-2008 09:04 PM
CREEPSHOW
11-30-2007 09:11 PM
