Rockford 300w 4 ch. amp and what speaker?
Old 09-15-2011, 06:42 AM
1sweetglide08's Avatar
1sweetglide08
1sweetglide08 is offline
Default Rockford 300w 4 ch. amp and what speaker?
I'm getting ready to install the new Rockford amp and putting 6x9 Polk Audio Marine speakers in the saddlebag lids. I'm running a Sony headunit and Hertz 6.5 in the fairing. My question is, will the Hertz 6.5 be good or is there a better 6.5 speaker to match the Polk Audio's. I found a good deal on the Polk Audio 6x9 marine speaker on Amazon.com for $84.00 shipped.
Old 09-15-2011, 08:06 AM
streetglide44's Avatar
streetglide44
streetglide44 is offline
Polk mm6501 components
Old 09-15-2011, 09:19 AM
Fast FLHX's Avatar
Fast FLHX
Fast FLHX is offline
Focal
Old 09-15-2011, 09:25 AM
Kesean's Avatar
Kesean
Kesean is offline
I have the same set up and went with Polk in the fairing and lids with a Alpine head unit. Works for me.
Old 09-15-2011, 11:38 AM
Biggzed's Avatar
Biggzed
Biggzed is offline
Make sure you check the sensitivity rating for each set of speakers to get the best sound.
For example: I'm running ARC Audio 6x9's in my bag lids. They have a sensitivity rating of 86dB @ 1 watt. I also have a pair of Polk Audio DXi525's in the fairing. They are rated at 93dB @ 1 watt. That is a huge difference.
The response from mkguitar in my thread gives a better explanation.
https://www.hdforums.com/forum/touri...uestion-2.html
Hope this helps.
Zach
Old 09-15-2011, 02:47 PM
redrubicon2004's Avatar
redrubicon2004
redrubicon2004 is offline
IMO the hertz handle the power better than the polk 6x9's. I'm running the same setup and the 6x9's start to distort before the hertz.
Old 09-15-2011, 11:03 PM
1sweetglide08
How do you like your setup? If you were to change the 6x9's Polk what would you change to?
Old 09-15-2011, 11:38 PM
streetglide44
Keep in mind mm6501's aren't the same as db6501, the performance is better. Just like quality different on other brand levels.
Old 09-16-2011, 09:32 AM
1sweetglide08
The mm's are better you are saying right? The mm's aren't waterproof as are the db's.
Old 09-16-2011, 09:55 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
when u mix brands and models u can get some goofy sound,regardless of sensitvity or power handling all speakers have a different timber or tone,as a rule i use the same models for all 4 .
Quick Reply: Rockford 300w 4 ch. amp and what speaker?
