VSS voltage/speed data?
The VSS is digital.
It sends a pulse each time a tooth goes past the sensor and the ECM counts the pulses and works out how fast the bike is going.
So you cant drive your switch with this sensor directly.
One way to do it would be to buy or make a shift light. The shift light counts the spark pulses and turns on the light when the count exceeds the set point. you could use that circuit to count the VSS pulses and operate a relay to do whatever it is you are trying to do.
The VSS is digital.
Will this do the trick?
http://sailesmarketing.com/all-produ...-switch-relay/
That will do the trick.
Hey Jason, did you ever find out any more info on exactly what the PWM frequency values are, relative to speed? I'm researching that Speed switch/time delay relay we have been PM'ing each other about, and I have an idea, but I'm not sure what voltage/ pulse widths harley uses.
danzio
10-09-2016 09:04 AM
broncofiresmith
03-20-2010 06:34 PM
