Starting issues
Old 09-12-2011 | 06:35 AM
Firechaser1141's Avatar
Firechaser1141
Default Starting issues
I have an 2007 flhx and have been having trouble with it starting will not do it all the time has happend 3 times in a month. I can turn the switch on, fuel pump kicks on but has a squeekin sound hit the start button motor turns over but wont start. Turn the switch off fuel pump makes same sound again. I give it about 30mins with a few attemps in between and it starts right up. Has anyone else had this problem
Old 09-12-2011 | 09:26 AM
djl's Avatar
djl
Have you noticed the fuel level when this happens? Sounds like the fuel pump is taking a while to build up adequate pressure. The '05 models has some problems with the line between the fuel pump and pickup rubbing against the inside of the tank and developing a small hole which affected fuel pressure. The noise those guys heard was described as a "hissing" noice, not a squeak. Not saying this is your problem but if it is, it will get worse.
Old 09-12-2011 | 11:28 AM
Firechaser1141
It last time it happend I had around 3/4 of a tank it only makes the sound when u first turn ignition switch on for just a sec. It dosent sound like a hissing sound
Old 09-12-2011 | 12:46 PM
iclick's Avatar
iclick
How many miles on the bike? Have you changed the fuel filter yet? I would remove the in-tank paraphernalia and do an inspection for any leaks, including the fuel-pressure regulator where it mounts. While in there I would replace the hoses and filter, and also the regulator if you aren't getting a good seal there.
Old 09-12-2011 | 12:50 PM
Firechaser1141
The bike has 41k im not sure about fuel fiter ive only had it a month but ill start with that
Old 09-12-2011 | 01:58 PM
iclick's Avatar
iclick
I had around 47k when I changed all my in-tank hoses as well as the FP regulator, filter, and exterior hose. I had a leak around the regulator mounting point, but that wasn't causing the misfiring and bad-idle issues I was chasing. My problem turned out to be a bad TPS, but I doubt if that's your problem. Is your bike throwing any codes?
Hang in there, as these problems can be hard to diagnose. Keep us posted.
Old 09-12-2011 | 06:44 PM
Firechaser1141
No it never throws any coded its goin to the shop sat and gonna get worked on under warnty
Jason Meyer
09-12-2016 07:54 AM
Jetfever
12-15-2014 06:27 PM
akpackfan
EVO
06-30-2011 06:46 AM
wareever
Exhaust System Topics
04-17-2010 07:39 PM
thrillseeker
08-12-2008 10:13 AM
Quick Reply: Starting issues
