Headlight disabaling
Why? Much safer with headlight on all the time for driving. Bad enough people still can't see us. If your that adamant about doing it look at the wiring diagram in the service manual and trace it out. You will have to cut and splice a few things. I'm not going to tell you how because I totally disagree.
easiest way is to pull one of the wires for either Low or High how many people really use both anyhow. I run High during the day and Low at night just to even out usage on both but If I was going to want to go Dark I think I would pull the Low and run High all the time.
Other then that a relay and separate switch could be spliced into either as well to shut it off.
I might do this mod myself. Not because I want to ride with the light off but because sometimes when working on the bike I want the ignition on and not run the battery down.
Also, when I turn into my driveway late at night the headlight shines right toward my bedroom window and, even though there are curtains, it lights up the room and wakes my wife. I'd like to be able to avoid that when I work late.
Why, when someone asks a simple question, do so many assume there is a sinister motive behind it?
