Headlight disabaling
Old 09-11-2011 | 03:07 PM
Stiggy's Avatar
Stiggy
Originally Posted by andyp
The main reason I want to do it is I like to run my spots without the drain of headlight during the day. I am also running an amp with my stereo. And I know my charging system puts out enough .
So you admit that the charging system puts out more than enough juice to run the headlight and amp, but you want to disconnect it to save power anyway.
Well alrighty then! Why don't ya' just kill the spots?
I'm obviously missing something, is this gonna' be the next fad?
Old 09-11-2011 | 03:19 PM
mmcbeat's Avatar
mmcbeat
I'm thinking that you probably have an accessory switch on your scooter that you are not using. Just rewire your headlight so that the accessory switch breaks the circuit when in the off position. Problem solved.
Old 09-11-2011 | 03:23 PM
faapilot's Avatar
faapilot
Originally Posted by piasspj
Ball peen hammer, quick, inexpensive and so simple a caveman could do it.
+1 on what he said...while you're at it, kill the brake light and turn signals too...go dark or go home..and learn to spell disable too.
Old 09-11-2011 | 10:13 PM
Matt0987's Avatar
Matt0987
If you do not have an accessory switch, add one and do as suggested.
Old 09-11-2011 | 11:07 PM
BBStacker's Avatar
BBStacker
Originally Posted by Jim Dawson
I might do this mod myself. Not because I want to ride with the light off but because sometimes when working on the bike I want the ignition on and not run the battery down.
Also, when I turn into my driveway late at night the headlight shines right toward my bedroom window and, even though there are curtains, it lights up the room and wakes my wife. I'd like to be able to avoid that when I work late.
Why, when someone asks a simple question, do so many assume there is a sinister motive behind it?
1. Battery tender will cure the ignition issue
2. Hit the kill switch, turn the ignition switch off(promise it won't lock your bars), coast into the driveway
As for the OP once you get it done, make sure you find the very LEO you can and ask him his opinion on your set-up. Preferably a Motor.
Just bustin ur peach pits guys.
Old 09-12-2011 | 02:16 AM
jty's Avatar
jty
When working on the bike, just pull the lights fuse.
TimHixson
04-13-2013 03:18 PM
Mimo951
10-31-2012 09:33 AM
Freightran
09-21-2012 10:17 AM
Bigstick
09-07-2011 04:51 PM
pons
06-22-2011 07:16 PM
Quick Reply: Headlight disabaling
