Agitator Wheels on a 2009 Road Glide
Does any one have the Agitator wheels on a non-abs 2009 Road/Street Glide?
I bought a set of used Agitator wheels from a 2010 CVO Street Glide with ABS. I attempted to install the front on my 2009 Road Glide. The dealer told me that the stock 09 RG spacers will work and they also told me that the ABS bearings already in the Agitator wheels will also work on my non-abs bike. Bearings seem to be the same dimension wise. The spacers appear to be different. The 09 non-abs spacers from my 09 will not work, to long.
So I contacted Zanottis and they said that I need the HD wheel installation kits for the front and rear. So I just received the wheel kits and guess what? No freaking spacers! I am only attempting to install the front wheel right now. Not sure what I will run across with the rear wheel.
Can anyone out there help out?
THANKS!!
THANKS!!
Instruction sheet for the rear agitator wheel (scroll down to the wheel installation kits to see the pn#'s for the spacers, etc.)
Instruction sheet for the front agitator wheel (scroll down to the wheel installation kits to see the pn#'s for the spacers, etc.)
I bought both the front and rear installation kits. I have only opened the front kit. No spacers come with the kit. So all I have for spacers are the stock 09 spacers. They will not work. They appear to both be to long.
I need part numbers for the spacers that are required to center the wheel between the forks.
No idea about the rear yet.
As I read it I do not see where the instructions mention any thing about spacers. There are spacer like rods that insert into the hub of each wheel but no mention of spacers. It implies that you re-use your existing spacers for non-abs application. Gong to the dealer with all of my stuff and will try again to get these wheels on my bike.
