FLHRCI vibration problem...Advice
I am having vibration problems all of a sudden too on my 08 FLHRCI.
Vibration is at any speed.
I also feel it when stopped at stoplights, and under my floorboards especially on the highway.
I thought about a badly balanced new front wheel, but wouldn't I feel something unusual in turns? And that wouldn't be a problem at a stoplight.
Bike handles normally. The vibration frequency gives me an upset stomach.
I have also noticed some of the rubber mounts for the exhaust pipes deforming and shrinking. I'm also assuming this is possibly because they are drying out and need to be replaced. could it be the same with the rubber motor mounts? Are the two made out of the same rubber?
I personally favor the idea of a rubberized motor mount issue, but I would like as much input on this as possible before I make a move.
If it is motor mounts, is replacing them an easy dyi?
Bike has 15,000 mi. and is 2.5 years from new.
Thanks to anybody.
-cjf
Thanks to anybody.
-cjf
wouldnt hurt to check the basic's...spark cables...plug correct tightenss....there was even a case or two of the insulating electrode on the plugs sliding up and down causing havoc.
