HD Garage Door Opener / Liftmaster
Has anyone been able to successfully hook up their H-D Garage door opener receiver to a Chamberland Liftmaster garage door opener? My Craftsman died in an electrical storm, and had to be replaced. I also had to replace the H-D receiver. It is programmed correctly and the light blinks when I hit the high beam. The light on my garage door button on the wall also blinks, but the door does not go up or down (it did once) I've connected it up directly to the opener, as well as to the button/switch on the wall, same result. I may have to take back my praise for this thing.
HELP!
Thanks,
mikebaby
HELP!
Thanks,
mikebaby
If your new opener came with a fancy wall switch that does extra stuff just unhook it and try the HD opener again.
https://www.hdforums.com/forum/touri...l?ref=esp-link
I did this instead of trying the Harley one. I took one of the extra remotes I had and paired it with the garage door opener on my side of the garage. I removed the battery from the opener and took the cover off. FOund where the button connected to the posts when pressed and soldered them together. The ran two wires from the battery terminals on the opener. Ran the hot wire to the high beam wire on the headlight and the other to ground. Mounted the opener under the fairing and when I flash the highbeams the door opens.
Some do. My Genie came with one for the auto, looks just like Dennis's, that uses a 12v batt the size of a double A chopped in half. The one I wired to my intercom push button on the Ultra Classic is a key chain remote that uses a regular double A 1.5v. Left that one with a battery and wired the switch instead of trying to drop the voltage down.
