Maybe someone can shed some light (pun intended) on this issue I am having with LED signal install on my 2012 FLHX. I installed Custom Dynamics/Street Magic LED clusters in all four corners as well as a Biketronics Smart Equalizer. Well for some reason the left front signal was alot dimmer than the right. First and obvious thought would be a bad cluster. So I switched them and got the same results. Left side was nowhere near as bright as the right. This isn't slightly. It is substantially different. I even tried it with the Smart Equalizer disconnected and got the same results. So any ideas what could be causing this???
You got a short/bad ground/bare wire SOMEWHERE! Good luck with that..I'd be back at the dealer with a NEW bike, oh wait, your bikes are always new.LOL....See you in a couple of weeks
I have seen owners install a bulb the wrong way around- that's why I asked.
and same with equalizer disconnected?
any change in the front if you change the rear on that side?
Mike
I went out and purposely tried to put it in the wrong way. It would take some force to do it. No change with the rear changed either. Does it no matter what.
Soooo how do I search out a bad ground or a short guys??? Or do I let the dealer handle it.
