Spark plug wet....gas smell? WTF???
Decided to check out condition of spark plugs and they looked great - I put them back in and tried starting the bike and it started but ran at extremely low idle for 20 second and then quit. I pulled the plug on the rear cylinder and it was wet. smelled like gas. Never had this happen.
What happened and what now???
Update: I adjusted the idle screws to get it running at a good idle - but, it seems that even at a cold idle of 1100 it is running differently....not a smooth idle - the exhaust at the back end sounds fairly normal but the engine seems to be going chug-chug-chug-chug and maybe the engine is bouncing a bit more?
LAST UPDATE: must have broke a spark plug wire - I changed the wires and the newly fouled plugs and it fired right up. Thanks for all the suggestions!
Well, by looking up into the wire I can't tell anything and I really don't know how to do much more than that to test it. Thanks - maybe a trip to the dealer.
Yes I did check a couple times that I pushed the wires on tight. So, to do that spark test, do I just pull the plug, attach it to the wire and then hold it against the side of the cylinder and then start the bike? Thanks for your help.
