Sudden oil pressure drop
Old 09-04-2011, 10:10 PM
WingMaster88's Avatar
WingMaster88
WingMaster88 is offline
Stage II
Default Sudden oil pressure drop
The bike is a 2002 FLHTCUI, 88ci, injected. Oil pressure had been consistent at 32 until a couple months ago when it jumped up to about 40 at 2500 rpm. I checked the oil level and thought it was reading about a quart low so I added it. Ran it about 100 miles, then this morning I started it up and it dropped to nearly "0". Would only come up to 10 at 3500 rpm. Did overfilling the oil cause the problem? Does anyone have any idea why it the pressure went up and fell of the table? I am not a wrench-turner and need some advice.
Thanks
Old 09-04-2011, 10:32 PM
flhtupser's Avatar
flhtupser
flhtupser is offline
How many miles on the bike? Cam chain tensoiner shoes could have sent a piece through the oil pump. I would not run it until the cam chest is opened up and oil pump, cam plate and shoes are checked. At this point you may have gotten lucky. I may be off with my assessment but that is what I would be doing if it were my bike. Good luck and keep us posted on your find.
Old 09-05-2011, 12:53 AM
jurob's Avatar
jurob
jurob is offline
Verify with a mechanical gauge.
Old 09-05-2011, 01:08 AM
CT-Bagger's Avatar
CT-Bagger
CT-Bagger is offline
Check pressure sending unit and gauge.
Old 09-05-2011, 07:08 AM
Sgt. Fury's Avatar
Sgt. Fury
Sgt. Fury is offline
I would pull the cam chest cover and take a look. Most likely is a cam chain tensioner shoe broke off a piece and it scored the oil pump surface.
Old 09-05-2011, 08:04 AM
Neil's Avatar
Neil
Neil is offline
If possible check with a mechanical gauge. Depending on mileage you may need to inspect tensioners. Mine were shot at 32,000. My indication was fluctuating oil pressure readings.
Neil
RDMC
Old 09-05-2011, 08:41 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
With a 9 year old TC,i would check the tensioners and cam chest as said before.
Old 09-05-2011, 08:45 AM
DTTJGlide's Avatar
DTTJGlide
DTTJGlide is offline
Sorry to say it sounds like it could be the tensioners,if they haven't been replaced I would check them before running it again, you might still get lucky & not have to do a complete rebuild.
Old 09-05-2011, 08:51 AM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,808 Likes on 3,167 Posts
Do the easy stuff first...Check the pressure. Old sending unit, Old guage.
And as an owner of an old TC also, I assume you know to keep an eye on your tensioners too.!
Old 09-05-2011, 09:04 AM
DTTJGlide's Avatar
DTTJGlide
I usually agree, but I had the same thing happen & tried replacing the sender with no luck, the tensioners were toast. The more he runs it the more chance he has of doing major damage to the engine, plus there's no reason to spend money on a sender or gauge, if anything check with a mech gauge, which usually means taking it in or buying one. If the OP checks back in with more info we can give a more educated guess, IE miles on bike & have tensioners ever been checked.
Quick Reply: Sudden oil pressure drop
