Fuel leak 08 EG
Fuel leak 08 EG
I just got everything together from my stereo install, and rode down the road to check it out, when I felt something wet hit my left leg. Turns out it is a fuel leak coming from what I would call a petcock on a carb bike, but not sure if that is what you call it on EFI.
Anyway, I made sure the upper nut is tight in the tank, but the middle section between that nut and the black nipple that the hose connects to is loose, spinning freely, and that is where the gas is coming from.
After tightening the petcock(?) down, it made it worse. Any suggestions?
Found it. Here is the thread. Hope the O-ring is the same size on the 08.
https://www.hdforums.com/forum/touri...-07-ultra.html
the dealer will tell you that you need a whole new assembly.
the o-ring is the same as the oil drain plug i believe. You need to dig the original out with a dental type pick and match it up. Grab a couple and stick one in the tool box.
I had the same issue and i was able to easily correct this myself.
